XM Issue - Can’t change stations
LOUSCRW
Warner Robins, Ga
Got in the truck this afternoon, and realized I can’t change XM stations. When I use the arrows on the steering wheel, it scrolls through the presets on the bottom of the screen, but won’t change to that station. When I touch the screen, nothing happens.
All other sources are working as intended.
I made a quick visit to Dr. Google and only found some stuff from 2021 on different Ford models experiencing the same thing, and it appeared to be related to an update.
As far as I can tell, the last update I received was in February.
Anyone else experiencing issues?
LOUSCRW
LOUSCRW
Warner Robins, Ga
did your truck try to download new s/w?
Honestly, you’re 50% likely to hear a DJ yapping with xm.
No, doesn’t appear to be an attempted download and you’re pretty much on point about XM DJs. On the bright side though, everything was working fine this morning. Not sure what the glitch was yesterday.
I had a Ford Pass glitch, would not respond to the start signal at all, multiple attempts. happened maybe ... 2x more in 7 years. Again, resolved itself and worked fine later.
both of us seem to have #FirstWorldProblems
