VGL-3Z-18808-A Install on 2017 802A
Y’all I cannot find the damn wiring harness to connect the kicker sub in to ?! I have loooked everywhere near the C uuupost and followed the trim down to the floor… nothing.
Can anyone help me on this ?
Pictures would help!
Thank you !
Welcome to FRF
Pictures. Or it’s really a prius
super cab or super crew?
Factory Kicker sub or aftermarket?
any existing modifications to the truck or stock?
I cut a sub into the stock wiring; post entitled “added a sub” circa ... 2017 I think.
IIRC, the entire audio harness is located in the driver’s side, rear pillar. connector is ~ 1.75” wide, has power, ground, all audio channels etc. so it’s a busy harness.
(SCREW)
I
2017 raptor SCREW with the factory Sony subwoofer. Everything is stock. I purchased the kicker OEM sub to replace the Sony sub setup and when I opened up the trim I could not find where to connect the wiring harness that came with the kicker setup
Got a pi or 3 to share? I haven’t opened that area in a few years
I
There is a couple pics. It has an existing harness that has 3 males plugs on it that go in to the factory Sony amp and one that travels over to supply the sub itself. In opening up the c post. There is no other option to “plug and play” the new kicker setup.
I
Here is the harness supplied to connect the kicker amp and speaker.
Hmm.
You’re right. It doesn’t match any connector. My best guess... contact Kicker c/s and see if they have an adapter - because I’m betting it should plug to the sub harness you pictured, coming off the amp.
Alternatively, see if it’s actually the correct part for the SONY F150 Raptor and not the ’18+ B&O Raptor.
