VenomRex 601
Nick@Apollo-Optics
Kurator
NYC
Heya Nick! Quick question for you. Can I use 325/60/20 tires with 20 inch VenomRex wheels?
Like without any modifications to the truck?
Kurator
NYC
Also, do you normally buy 5 wheels to keep one under the truck?
Nick@Apollo-Optics
That's a negative, ghost rider. You'll need to raise the front suspension and do some minor trimming to your fender liners for clearance. If you don't mind doing those, I highly recommend the 325s. They look perfect on the truck with 20s and that's what we run on our Raptor. Here's a couple albums with the VR-601 and the VR-602 on our Apollo Optics truck.
VR-601 Bronze: Ford Raptor - 20" VR-601 Patina Bronze 20 photos · 1,051 views
VR-602 Carbon Graphite: Ford Raptor VR-602 Carbon Graphite 20 photos · 461 views
Are you aware that Raptor is a Leadfoot?
Well, I am now. Nice catch.
Here's Magnetic w/ Carbon Graphite VR-601 on an F-150:
https://www.flickr.com/photos/venomrex/albums/72157666923273338
Kurator
NYC
What am I missing here? Are those tires wider then OEM? Because the diameter seems to be almost the same?
Nick@Apollo-Optics
They're taller and wider. The OEM tires (315/70R17) measure out to 34.4" tall and 12.7" wide. The 325/60R20 measures out to 35.4" tall and 13.0" wide.
Kurator
NYC
So those fender cuts needed only in the front? Is **** Geisers + Icons option 2 works ok with this tires? Can normal mechanic shop trim those panels? You have like image of the size of that trim? Thank you mate! Appreciate the info!
Nick@Apollo-Optics
The trimming is very minor. You don't even have to do it if you don't want to. It's only minor rubbing on the fender liner at full steering lock. A hot knife, sharp knife, Dremel, or sawzall can quickly knock it out. You'll still need to do the trimming with raising the front. You don't have to go option 2 on the Icons unless you want to. You can clear this in the rear at stock height. I don't have an image of the cut, but it's basically a 1" wide x 2" tall cut on the fender liner and you're good to go.
