TSB 22-2428 10R60/10R80 Transmission
scpete24
SoCal
Looks like this TSB was just issued last week regarding the transmissions mentioned in the title. Anyone have additional information on it? All I got was the screenshot below from a buddy but can't find anything online regarding it and hoping to get some more info.
thatJeepguy
GA
For the most part my transmission is butter but every once and a while it has a weird jerky shift… i wonder if this is why..
FordTechOne
Detroit
That is simply an update to a 2 year old TSB.
TSBs are not public for this reason. Everyone who owns an included vehicle believes they have the problem or go looking for the problem. Then they bring it to the dealer wanting the “fix” for a condition they don’t even have.
scpete24
scpete24
SoCal
Thanks man, just didn’t know. Been having the jerking from P to D and some harsh shifting. Resetting the adaptive tables helps but only for a little while. Was hoping this might have been a perm fix, but doesn’t sound like it.
Another question from your response, is it possible to turn off the adaptive learning altogether and just use the stock tables from ford?
sc85fiero
North Port FL
Is it possible to turn off the adaptive learning altogether and just use the stock tables from ford?
Not to hijack, but yes it is possible to turn off adaptive learning but I wouldn't recommend it. It not only adapts the shift points, line pressures and shift time/lag/flare based on the driver's habits, but it also adapts to normal internal transmission wear and tear. It would probably end up making your clunky shifting worse in the long run.
-Joe
FordTechOne
Detroit
When the adaptive tables are reset the drive cycle needs to be performed, otherwise it will not relearn properly. The Adaptive learning is only intended to be turned off for diagnostics, not indefinitely.
Here’s the procedure:
scpete24
scpete24
SoCal
Awesome appreciate it man!
