Rubber around interior driver door jam rattles….
hyrepower
Las Vegas, NV
On the freeway the rubber around your ear that goes around the door rattles. You can push it in as it seems to comes unseated, but it just pops back out.
I had this same problem on my tremor, but apparently they didn’t fix the issue. Anyone have any ideas other than glue.
awd5906
NY
I have the same issue. It seems to come and go. Especially if the car sits around in the sun. I’ve lubricated the seal which helped a little. I put some tape on the underside of the seal as well and that has helped but I can still hear it once in awhile intermittently. I am going to the dealer next week and will ask them to take a look at it and hopefully I’ll get some good news.
DFS
USA
@hyrepower @awd5906 Did either of you find a solution to this? I have access to adhesives that seem suitable, but if there's a dealer solution I'd much rather have their fingerprints on it than mine.
H
hyrepower
Las Vegas, NV
No, I sold the truck, I have had a 23 37PP that has been in the shop for the past 3 months with factory paint defects, getting PPFd, tires, wheels, spray in bed liner, tint, and ceramic coated. 3 motnhs I have been without the damn new truck due to the F'ing paint defects getting resolved. ****** me off.
Quality control is a thing of the past, not just with Ford, but everything!
DFS
USA
That sucks, sorry to hear that. Hope something works out of for the better...
awd5906
NY
They apparently took the door apart and lubed and tightened things but it still rattles once in awhile. It’s always after I’ve been parked in the summer heat for hours. Always around the lock tab area. If I put some pressure against that area like pressing against it, the sound will go away. Some days are better than others, I’ll have to bring it up again next oil change in 5k miles. I also had the A pillar rattle but that was easily fixed with felt tape and a YouTube video.
TremorRaptor
Washington
My Gen 1 developed a door rattle too - it turned out to be the door seals. My fix was to use Gummi Pflege! When I get around to it, I'll preemptively treat my new door seals with this too.
H
hyrepower
Las Vegas, NV
I am going to use a dab of windshield silicone adhesive, about 2 x 1/4” dabs of it 1/3 down from top and up from bottom. This should be the ticket to stop that hard ****** rubber from rattling on the metal door. You’d think after 6 years ford would have rectified this issue.
