Darick
- Joined
- Feb 14, 2015
- Posts
- 43
- Reaction score
- 37
Look at that, two Trophy Trucks!
3M adhesive sticky.
Thanks! Maybe over time the tape will weaken but I imagine it's pretty solid right now that holds up off-road?
Thanks, I'm super impressed with how well it fits the truck too.
I'm going to add a bit more preload to clear the 37's better. It's probably about 1" over stock right now but I'm rubbing a bit more than I was with the setting I had on the SVC CAS. Probably only a couple threads down will be the sweet spot.
No way is this thing getting caged. I never even used it on the other truck. Hahaaa
I was just told the out of the box settings for the Kings would place the front at approx 4” over stock. Did you or the shop lower them quite a bit to have a more level ride? I’m leaning towards them but not much info out there. Does the rear sit higher with the Kings and is there any height adjustability in the rear from the shocks?
I’m trying to get approx 2-3.5” over stock for 37s but don’t want the rear to sit way lower. I’ll go with Deavers but unaware of any other way to get the rear to match the front of “out of the box King Raptor settings for the front” if that’s true.
I love your truck! Lol
Thank you!
I don't think they were quite 4" over but they do make the truck pretty level. I had to add more preload to them to get them to clear the 37's. You can easily adjust the preload on the fronts to get your desired ride height.
