GEN 1 Odd noise on acceleration
DLaughlin
Mobile Al
Good evening fellow Gen1 owners,
I have been experiencing an odd noise when under heavy throttle. Not sure how to describe this noise. I am posting a yt link to a vehicle with the exact noise I am describing. Not my vehicle but the tone, duration, and operating conditions are same. Would love input if some has anything. I am stuck between iwe check valves leaking or possible bad torque converter.
FordTechOne
Detroit
Could be an IWE issue, that doesn’t automatically mean it’s the check valve though. Try engaging 4WD (only when driving straight, Gen 1 is a part time system) and see if the noise goes away. If so, suspect an IWE related issue.
Raptupkiwi
new zealand
Newbie here and hello from New Zealand I have a 2014 scab with only 31000 miles on lt and i have the exact same noise but it only ever does it when the trans changes down to 3rd from 4th and only occasionly. Usually does it when driving into town through the hills that have lots of tight bends from where i live and once on open road it doesn't do it again. I am thinking it's a transmission problem as it only ever does it as explained above but would appreciate some feedback..... FRF ROCKS
Folive123
Southern California
My truck is doing exactly the same thing , would you able to fix the problem?
ograptor
Masshole
I pulled the vacuum for the iwe. That locks them to the diff, correct? The noise is still there, unless i put it in tow/haul mode.
ograptor
Masshole
So, i ran all new vacuum lines to the iwe's and the noise is still there. After a transmission and transfer case service, the noise is gone
Gumby
Nashville
LOL. doesn't mean you are not turning the front axel and driveshaft. I can see I need to do a how to check if your IWE is bad. POST.
