NEW PRODUCT | KR Off-Road Air Compressor System for 2015+ F150
4x4TruckLEDs.com
NEW PRODUCT ANNOUNCEMENT
We're happy to announce that our new KR Off-Road Air Compressor Mounting System for the 2015+ F150s and 2017+ Super Dutys is available for pre-order.
This mounting system is made here in the USA out of stainless steel (final product will also be powder coated black) and allows you to mount an ARB or similar compressor (such as the UDA EGOI 2) in the bed of your F150. You can mount this on either the driver side or passenger side.
The mounting platform utilizes the existing cleat bolt pattern and you STILL RETAIN use of your bed cleats. Included in the kit is our power extension harness w/grommets which makes installation easy. Just connect the included power harness directly to your battery, plug in OUR extension harness and route it to the rear of your truck. We even include a grommet to protect and dress up the wire. Then plug the harness into the compressor. No splicing wires or cutting wires. We also include our switch panel that mounts on either side of the compressor and plugs directly into the compressor (no running switch wires either, it's all plug and play).
I've been running a similar setup on my F150 for the last year but now we're making this available to the public due to demand.
Through July 7th you can save 15% on the entire kit when you pre-order it on our website (discount will automatically be applied at the cart).
https://www.4x4truckleds.com/kr-off...kit-for-2015-ford-f-150-2017-ford-super-duty/
4x4TruckLEDs.com
4x4TruckLEDs.com
Our brackets are in stock and we'll be shipping kits out next week! We're just waiting on our wiring harnesses to arrive to us.
Here is a photo of the kit installed on our shop F150. Pretty straight forward installation nothing crazy to it. Just run the wire harness from your battery, under the truck along the frame rail and through one of the grommet openings in your bed. Then bolt up the bracket to one of the 4 available cleats in the bed. No crazy wiring or splicing involved either. Our switch plugs RIGHT INTO the arb compressor, so you don't even have to wire anything honestly. Just plug it in!
Pre-Order your kit here and use coupon code RAPTORFORUM to save 10% on the entire kit: https://www.4x4truckleds.com/kr-off...kit-for-2015-ford-f-150-2017-ford-super-duty/
4x4TruckLEDs.com
4x4TruckLEDs.com
Our harnessesa are back from production. Orders are now shipping out the same day they are placed.
