Needing Input Please - Transmission Woes
B
BSouders80
NW Arkansas
So the drum brake for the e-brake is a thing? I guess that makes sense. I did install some moritomo Xb headlights and was using the e-brake a few times to check drl and turn signals. Dang it. Oh well, I’ll fix it and move on. Thanks all.
bwep
Mass
My caliper slide pins dried up, no grease. this was at 60,000 miles. Would make some strange creaking, popping noises. Replaced pins, greased. Pads and rotors were still in good shape. No more strange noises from the back.
Canuck714
San Antonio TX
The bulkhead connector on the 6r80 loves to leak, I'd have that checked out for sure, mine dumped a quart of atf on my driveway one time, replacement was real quick and pretty inexpensive. Good luck man.
This is the most common leak spot .
That connector is only good to be reconnected a time or two. It leaks down the back side and has the same drip pattern your picture shows.
While you are replacing the rear trans seal, I would replace the seal on the output of the T-Case. Having the slip yoke in and out a bunch lately, you may end up with a leak there soon..
