Moon roof rubber gasket seal maintenance, what lubricant?
Monte87
Monte87
NY ******
Yes, the microfiber around a credit card I think is what’s actually suggested in the tsb, and is the best way to get the rear fixed panel (alcohol on the towel first, then once clean out the grease on a clean part of the towel).
Got it!!!!!! Thanks so much for the clarity =) and sage hahahah
Ant
New recaros
Colorado
A small plastic puddy knife is the way to go. I took some sand paper to all the edges of the plastic knife to ensure no sharp edges. I put that expensive lube stuff along the rubber seal, wrap the end of the puddy knife in a microfiber cloths and run it along the edge to distribute the lube.
I never clean the rubber with alcohol as it dries it out.
Monte87
Monte87
NY ******
Hey guys!!
So i did the moonroof lubricant maintenance yesterday and it went well. I used the entire tube of Krytox and have to buy another, its tiny!!! The AAA card w microfiber towel worked PERFECT!!!!!!!!!!! slid in like butter.
Question --> #1) I want to lube the track of the moonroof as well. What lubricant can i use for that? The dealer put some grayish grease on it, but it looks old and i wanna do it all at once and be done. So the track is a must!
#2) How often should i perform this lube the moonroof project?
Thanks Anthony
Monte87
Monte87
NY ******
I did the exact method but used a AAA card as it was thin and flimsy and glided between the rubber and body. Let me ask you though, did you use the steady stream of lube along perimeter? Or small drabs and dots to conserve the grease? I used the entire tube on roof. lol
I also used my finger to smear it on the glass rubber to lubricate that hard rubber as well. It was quite messy
Thanks Ant
Donmatteo
Santa Clarita / Coronado
Hey guys!!
Thanks Anthony
Yes. 100% you want to do the track and the plastic parts of the track. Open the roof, apply to the tracks and cycle it a couple of times and I would say every 6-12 months. If you live in a dry, hot area, every 6 for sure.
I think you're using too much of the product. 1 little tube should be enough for a couple of applications. (insert lube sex joke here for @Oldfart )
Oldfart
I can testify to the fact that too much lube leads to issues, such as matting of the fur, and needless mess in my truck!
