Yeah, not sure if it’s mentioned in this thread or one of the others, but one of us damaged the slip yoke, and I believe it was attributed to improper adjustment(?) at time of install.
I’ve had mine installed about 8 or 9 months maybe... I had it for a while as parts in the garage.
The install took me a weekend because I was cognizant of the bracket clearance issues, had to fully install the shield to confirm I would have the problem, de-install the shield and move on. You also have to move some brake lines running along the axle, including bending them which I was not comfortable with but got through it without drama. Also, the top of the diff housing brake line bracket is problematic after installing the torque arm. the rubber lines are able to rub hard parts now that there’s new hardware in their way. Instructions have you bend the bracket and ensure the lines have enough slack for full suspension travel. The lines form an “S” but they love to bend inverted so the lines hit the torque arm. I ended up putting some sheathing and a loose tie / loop close to the top to prevent this. it seems to be working. I could be erring on the side of paranoia here, but I’ve lost a rubber brake line before and don’t want to do it again.
ok, so that’s out of the way.
function: 100-150% improvement. This is tough to quantify, because the stock rear leafs are so easy to wrap and induce axle hop. It was most evident at Raptor Assault, when you’d do a full throttle take off you’d get wrap and hop as soon as the hair driers spooled. You can get this on pavement too but more easily noticed on a surface with less traction like mud or sand.
After installing the torque arm this is radically changed. I can’t say if front to back movement is 100% eliminated or if hop is 100% eliminated, but the effect is that flooring it results in the truck moving straight forward despite having lost traction while you’re spinning your wheels. There’s literally no pounding sensation from the axle hop. Before doing this, the truck required some steering correction all the time.
I’m sure the traction bar customers can articulate similar findings.
