Intercooler install tips
MrTorque
Leave it unplugged. It will show an code in forscan but will not throw the wrench on your dash. It will be fine. I taped the end so water would not get in it and cause an issue
Appreciate the help.
MrTorque
Went with the Cobb(if it’s what @GooseTuned plans to use it’s good enough for me)I also opted to plug the shutter motors back in and tie them out of the way, just so I know the truck isn’t throwing codes. Appreciate the help from everyone! *did not need to remove the bumperDE498038-5D90-4F43-BFFA-D237638D56AE.jpeg
cdiddy4224
USA
Went with the Cobb(if it’s what @GooseTuned plans to use it’s good enough for me)I also opted to plug the shutter motors back in and tie them out of the way, just so I know the truck isn’t throwing codes. Appreciate the help from everyone! *did not need to remove the bumperView attachment 369612
which COBB IC did you go with? Front mount which is a bit more or the factory location?
GooseTuned
New Mexico
There is one other particular thing I know we need from COBB asap. Any update on their end?
Nothing yet. They will likely announce parts at the same time as tuning, that's generally what they do.
