6.2 Header bolts
mpk1996
About to install my headers. Got a set of used SW headers. Got some heat shedding for the starter and spark plugs.
I plan on just using rtv and/or stock gaskets. Maybe stock bolts, but was thinking about going with some 12pt as they are usually easier to get a wrench on (my experience with the race car) plus they just look cool IMO.
Don’t really like the stage 8 stuff. For a 2012 are they are M10 x 1.25? Also any idea on the length? 30mm? Longer/shorter?
Any reason not to just order these?
Vash
OK, USA
I can’t 100% confirm since I had my installer use the Stage 8 locking bolts, but 10mm x 1.25 is the correct thread pitch, so you should be good as long as the length is correct.
FYI. Summit lists the underhead length of the Stage 8 bolts as 25mm.
