GJ Motorsports 3rd Brake Light Install
signalbobby
After receiving my GJ Motorsports 3rd brake light and noticing the instructions are terrible. I decided to do some good research and figure it out on my own and hopefully, this makes it easier for the next person. First off, I received mine without the connector to plug directly into the stock harness so I had the vampire connectors which made it a little more difficult. Below is a basic wiring diagram (if you have the connector) that I made. Please note all the wires that you are connecting to the truck harness have no ends on them if you received it without the connector like mine. If you have just the vampire connectors just take the connector for the truck harness out of the equation and you still connect the wires to the same spot. On my 2021, the blue marked wire was to the purple wire on the truck harness. The wire from the "in" on the reverse harness went to the white wire on the truck harness. The red marked wire went to the red on the truck harness. The black wire went to the black wire on the truck harness.
I had the NMO mount and the cable wasn't attached as well. This was pretty straightforward since the screws are different sizes and the cable ends are to accommodate the proper size screw. Just make sure you also use the plastic washer on the antenna cable between the connector and the antenna to prevent it from grounding out.
Running the cables was fairly easy. You just need to pop off both the front and rear door sills on the passenger side and then remove the cover for the fuses on your kick panel. I was able to pull my headliner down just a little bit to grab the cables and then routed both the nmo antenna cable and the wiring harness behind my c-pillar, then through the bottom of the b-pillar, and then just the harness to the kick panel. The nmo cable, I was able to route to my center console through a divot you can find below the passenger side seat. If you follow the wiring harness, you will see it T off here and there is enough space to run it under the carpet to a part that is cut out under the seat that you can pull it through there. I then removed the back side of my center console to route the cable there to my icom radio. I also used the youtube video below on how to remove the center console. I drilled a hole on the back driver's side of it to accommodate the cable size and then the rubber mat also covers it so you can't even notice it is there when it is removed.
Removing center console:
I ended up terminating both side S2 lights into a weather pack connector and then pulled the wire for the 6th upfitter switch to run both at the same time. You could also use the Y connector right off the lights and just use one of the wires to terminate into the upfitter wiring harness. Remember if you want to use the upfitter wiring in the kick panel, you have to connect the two wires by your battery in the engine bay for that same upfitter switch to work.
I grounded the cable to the 10mm screw by the fuses. This is also where I put my ground for my icom radio.
The last part that was more confusing is where to attach the reverse harness. The GJ motorsports show the cable location and color as green/brown. There was no green brown cable located where they show on the instructions. I can tell you there are THREE Green/Brown cables. There is one with a very thick green and brown color, this one IS NOT the one you want to tap into. The other two green/brown cables actually go to the same location. One is the same size as 80% of the other cables in the harness and one is much smaller. I tapped into the one that was the same size as the majority of the wires in the harness. In the fuse diagram below, I rotated it to show the proper way up as you will see it in the kick panel. I attached the vampire connector right behind where the wires come into the fuse panel.
I hope this helps save some time for those looking to install this. I am not sure if there are any wire color variations between 2021 and the newer trucks as we have seen in the past, but the wires should be in the same locations. I wish I would have taken more pictures while I was doing this install but hopefully everything else is fairly straight forward! Also, if anyone sees anything that is wrong or unclear, please let me know!
THank you so much for this. Confused the shit out of me as well on colors. I had this on my gen 2 and colors are off.
Cookie
Canyon Lake
I just installed mine on a Gen 2, reverse light doesn't work at all. I did check to make sure the light itself works by itself and it does. Any thoughts on what would cause it to not work. I have triple check all the connections as well.
scpete24
SoCal
If the connections are good, then you wired it wrong. Helps to provide pictures of what you did for wiring, what you connected it to, what harness you have before you get roasted for it being your first post and asking a blanket question with no actual information other than I wired it up and it doesnt work...
thatJeepguy
GA
You have to tap the wire harness in the passenger foot well as per the directions.
BoostCreep
SoCal
Does anyone’s GJ leak a bit? After a very heavy rain the headliner is a bit damp and the GJ gasket is pushed down a bit when viewed from above.
Space Ghost
FL
Knock on wood none from mine and im in FL. I remember in the gen juan times these were seen as upgrades over the stock one which had some leaks.
Have you taken it off and seen if theres any water left in that area? And maybe try reattaching the gasket again? Also check if its your moonroof causing it
I will say the gasket (oem too) looks porous, but i havent had an issue with either.
DougDimmadome
East PA
None from mine but I replaced all the hardware with a better solution and really cranked it down. No leaks even in car washes
BoostCreep
SoCal
Yea I’ve pressure washed it a bunch of times without issue, and the leak wasn’t bad, not enough to drip from the headliner just a little damp. It’s definitely not coming from the moonroof.
I’m thinking of just coating the outside of the gasket with black silicone just on the top of the light. I currently put a strip of electrical tape there and after more heavy rain, no more leak lol.
velogil
Orange County, CA
I did the EVLMFG third brake light install on my 2023. I used this as a guide but if anyone has specific questions around the EVL one, let me know and i will guide you for that specific light.
Quick overview of the EVLMFG:
1. Don't need to drill on the GEN3. It uses the factory mount points as the OEM brake light
2. The only wires you need to splice in the back are the 4 wires shown above. Its basically BLACK-BLACK, WHITE-WHITE, PURPLE-BLUE, YELLOW-RED.
3. Remove the OEM battery, you'll save yourself a lot of headaches, trust me.
4. The hardest part is fishing the wires through the cabin. I didn't use the OEM pass-thru wires because its only 1 wire. I extended my double S2 wiring into the engine bay which is a total of 4 wires (power/ground for each light). Fish it using a fishing reel for electrical wiring and its cake
5. For wiring using the BD harness, cut the switch it comes with. You only need to connect the blue wire from the BD harness to your uplifter AUX wire. Black/white are not going to be used.
Thank you so much for this post!! Saving me a ton of time!! :)
velogil
Orange County, CA
by the way did you ever have any issues with water getting into the cab pocket from the EVIL not having a great seal? I may go back and install the nutserts so that i can really torque it down and compress the seal vs. the plastic nutsert they have there. ??
