General consensus on 4HI Baja mode
sixshooter_45
Arnold
Just a note, in Baja mode you can select 2WD and remain in Baja mode.
If jumping which I've never done nor probably never will, I'd do it in 2wd to stay on the safe side.
shigman
shigman
Cypress, TX
Thanks yeah, I do tend to use Baja 2wd. I was just wondering what people around here tend to do in a mixed off road environment where you want the 4HI sometimes, but maybe not for most of it. It’s not exactly quick, reliable, or safe for the truck to be popping back and forth while on the gas. I wasn’t sure if my diff failure in 4HI was a common thing, or I just had bad luck one time.
SurfRaptor
Newport Beach CA
I'm not a huge fan of Offroad and Baja mode. They seem like they keep the RPM's way to high for extended periods of time. Is it just me? Maybe i'm doing something wrong? My go to is 4WD High, rear locked, Traction Control off.
NinjaRaptor
Florida
I do not do any jumps as of yet, but i am usually in baja 2wd for fun factor and if it is really sandy i go 4HI..
For sure the RPM's stay in the high range in baja mode.
shigman
shigman
Cypress, TX
Baja mode also desensitizes the airbags and removes more driving aids than traction control alone. My goto is baja mode, advance trac off, 2WD manual. Takes care of the sustained reving when not desired.
I believe Baja mode also ramps up the brake line pressures too. Ive noticed this putting around after a run and locking up the seat belts, just tapping it. On the gen 2 anyway.
