GEN3 Forscan
RaptorFun
Northeast Wisconsin
Are you using the 2.3.60 test flavor of FORScan? If not…download it from Antho’s post above. Once installed…you should be able to successfully complete your project.
ChevyLee
TX
Yes I am. That's what ForScan sent me. I can access the truck now (previously couldn't) but settings don't actually write. This is a pretty common problem right now on the 24s.
Ifly4vamerica
@RaptorFun I did the edits for temperature on gauges and mine worked for both Trans and Coolant. It did not however work for the Oil Temp, are you sure you are looking at the trans temp and not the oil? This got me initially.
I also had same experience as you for everything else. Waiting on 4D Tech to get more in stock.
I also did the seat belt chime off per the manual, basically start the truck, let the chime stop, then inset and remove the seat belt 4 times. Seat belt icon flashes, and you are good to go. Do the same with the pax belt. First time I did it it reverted after a couple starts but seems to have stayed after the second time.
As a side not has anybody with a 2024 tried 720-01-01 in the IPC, it actually says auto stop start in there and looks like you can disable. Depending on your asbuilt data you may be able to make it happen there. I can't try it for a couple days until back home but just happened to see that in there.
Jepper84
Florida
I tried, I went through all the modules that i could see and shut off auto start / stop and none of them worked
Ifly4vamerica
Thanks for the info, I was at work basically searching for anything related and was going to give it a go. You saved me some time. 4D tech is where it's at I guess. They said back in stock in a few weeks.
Pushing that button isn't so bad, that's what I'm going to keep telling myself I til then.
ChevyLee
TX
you can save it in your R settings. So you just have to press the r button on the steering wheel twice, and you are good to go. My saved settings are sport suspension with Baja exhaust, and auto stop turned off.
Jepper84
Florida
Really you can save it in R settings? I know you can put it in sport mode and it turns off stop start but didn't know you could disable it that way.
Btw .2.3.60 officially released two days ago if anyone wants to try it.
Antho
Yeah. Thats what i do. I have it saved in my R mode.
zachery55
Rocklin, CA
So I’m having a hell of a time knowing what’s what with my 24. Truck lights are in auto. Always how I want them to be.
What I have enabled.
DRL with fogs
DRL with parking lights
Fog with high beams
Disable driver seatbelt chime
Disabled the start up ding ding ding chime
Change brightness on DRL to 75%
Removed the black box on camera view when driving
And attempted the walk away lock function which I’m guessing isn’t possible on the raptor.
I never had the double honk and my cameras always worked at speed.
As far as I can tell everything works except my DRL changes do not come on during full light. Only the stock headlight DRLs come on during the day. Once my “auto” lights come on the everything works perfectly. Figs. High beams. All DRLs with parking lights. Confirmed in neutral position with parking brake set.
My question is my auto lights only seem to come on when it’s not bright outside like in the shade or garage… assuming thats normal….?
When they do come on all my DRL features work. So I believe all my settings changed correctly but why do my DRL changes not come on in full sunlight? Why do they only come on when the auto lights come on in less then full sunlight?
I really wanted the drill lights and everything to be on at all times.. is everyone just rolling around with their parking lamps on and switching there lights on manually each night or am I missing something?
I have reset back to stock once already and reset all modules as well because I really thought I broke something. Like I said everything appears to work perfectly now minus that one thing. Which is of course what I wanted the most lol….
Did I miss something? Since the brightness and DRL with park lights are both on the same module line can I only have one inputted and not both?
I’m on day 3 here trying to fix this.
Please help me I am at your forscan wisdom mercy lol
@Antho @swoop1156
