Gen2 Live Valve Full Stiffness Cause?
downforce137
In Diana
my guess is the whole needle is stuck is the closed position, whether its grit, or the needles seat getting worn out and galled up.. something is wrong.
T
TravisHTX
Houston
I don’t think the Ar15 analogy works. Although very efficient in its application, it’s an open and overtly dirty operating system, where the shock is a closed system.
Also, props to you for humor for mentioning AR15 and reliable in the same sentence
A definite LOL.
Hey! I never said ARs are reliable! Just comparing a tight tolerance to a mil spec version!
Fair point on the closed system, I am just ignorant enough on the subject that I don’t know all the causes of a worn shock. To the uneducated, it would seem like if the seals deteriorate, that could potentially cause debris to be floating in the oil.
Yeah, I know enough about this topic to know I don’t know enough.
Or something like that.
Maybe a closer analogy would be fouled carbs?
Anyway, I’d be curious to hear the final diagnosis on this one.
T
TravisHTX
Houston
That may be more accurate, but I think we understand the gist of it. But yea, I grew up on boats, not cars, so I am out of my element compared to many of you here.
Anyways, both Kyle@ApolloOptics, and Rick at FMS had competitive pricing on Eclik and OEM rebuild. It was hard since both have been great and provided valuable feedback, but I had to pick one. Sorry Rick!! I went with Kyle@ApolloOptics just because I have worked with them before, and they are geographically closer to me. If any of you guys are looking at Eclik as an option, I don’t think you could beat working with either of these guys.
Unfortunately since I am doing both bypassing the VDM at the same time, and a shock rebuild, it will be harder to tell what was the root cause. If I have the time, I will see if I can run the rebuilt shocks before installing the Eclik. But since they are revalving them, I am not sure how that will change the ride vs OEM.
I will certainly update this thread.
Kyle@Apollo-Optics
San Antonio,TX
Travis,
Thank you for choosing us here at Apollo Optics. I sent you an update from SDI.
letsgetthisdone
Las Vegas, NV
Stupid question. What would you all say the odds are of some sort of grit (like particles from the worn seals), that may cause the needle valve to get sticky?
That may explain some reported cases where some hard use may dislodge that debris and the system behaves better for a bit. Or variations in perceived harshness.
I could swear that just today while driving on the road, while still harsh, the ride seemed a tiny bit better today without changing a thing.
With how much this needle valve moves, I would find it unlikely for any scoring in the piston to be unlikely, but I very well could be wrong.
I guess if you let the shocks go way too long between rebuilds and the wear bands wear out, then piston starts wearing on the body this could happen. But shocks that are in good shape don't make a lot of metal shaving. And the condition of all of these parts should be checked at every rebuild, as the seal kits come with the orings for all of those small components.
T
TravisHTX
Houston
Update:
I took the shocks off and sent them to SDI for them to do the rebuild. Got them back Friday afternoon, got them installed that night. While I was waiting for the shocks, I got the Eclik controller installed.
While I would say there was a noticeable difference, I honestly would attribute much of the improvement to having full control over the shocks.
With the controller, you are able to adjust the rear and front shocks separately. When I set the rear shocks to full stiffness, then compare to full soft, there is only a very slight difference. The front shocks, the difference is more noticeable.
So I guess that means either the solenoids or the valves themselves are the problem. I would think that SDI checks operation of the valve during the rebuild, but I will confirm that on Monday.
A local dealer was able to find the rear solenoids near by, and will have them on Tuesday. I had to order the front solenoids online, which will probably take an additional week.
All that said, I give a tip of the hat to Kyle@Apollo-Optics, and SDI. They made the process of getting the shocks rebuilt as easy as possible.
Even though the rebuild did not seem to be the ultimate fix, it still needed to be done. One of the shafts had pitting that could not be repaired, which the folks at SDI sourced and replaced (and didn’t charge me extra for).
I will give another update once I get the rear solenoids replaced.
T
TravisHTX
Houston
Alright guys, I am at a loss.
I replaced the 2 rear solenoids. No difference.
I talked to SDI, he said that they do apply some power to the shock in order to open the valve so they can bleed it. So assuming the valves were able to open then, then I am not sure.
I must be missing something. The only other thing I can think of is the needle valve/piston of the live valve mechanism is getting stuck.
