gen 3 bump stops
catinthehat85
Socal
What wheel travel are they sized for?
Edit, 99% sure that’s on a 37 so would be reducing travel for a 35 truck by 1”.
I don’t know about the SVC kit, but that’s not how the RPG and foutz kits work. They are designed around the 35 platform, meaning you get full piston travel with a 35 shock setup. On a 37pp you are limited by the extra height of the rear factory bumps, and thus lose about an inch of air bump travel on the RPG and foutz kit. I know this from direct experience. Don’t get me wrong they still completely transform the rear characteristics in tough fast terrain, but it could be an inch better =).
taquitos
Seattle
You remove the stock bump so you’d be limited by the bumper on the shock body if I’m not mistaken.
hyrepower
Las Vegas, NV
I have noticed the front loses travel long before the rear end does. I find I bottom out the front struts way easier that the rear. I think the rear suspension on these Gen 3s is a dream.
taquitos
Seattle
For the most part I agree. When heavy on the gas the rear runs out faster I think though.
hyrepower
Las Vegas, NV
Or with a load. The simple answer would be a one of these darn aftermarket companies (Fox, King, Icon) coming out with a set of suspension that has adjustable bypasses with internal bump stops. HINT HINT HINT
