Front end pulse
mzuern
wisconsin
I have a 22 37 package and trying to figure out a pulsing/vibration I feel in the front end and gas pedal. When I get to around 54-55mph i start to feel a pulsing vibration in the front end. It feels like some resistance on the front end and is definitely a feeling through the pedal. I believe my 22 has the torsen front end which I have read has a feel to it but haven't driven a non torsen to compare. I've had it to the dealer and mentioned it and they haven't done anything. Posted on a forum and a few guys started iwe. Thoughts?Any help would be appreciated. Thanks
BoostCreep
SoCal
I have the same issue on my 23 without torsen. I personally think it’s the front pinion bearing but saw the posts about IWE on your other thread (I think you posted on the fb Gen 3 group?)
I’m planning on taking mine to another dealer in the next couple weeks. It’s something in the front end for sure and I’ve ruled out wheel/tire balance.
mzuern
mzuern
wisconsin
I did mention it on that site as well. I just can't figure out what it is but know that it cannot be how the truck was designed to drive. I also notice it when letting off the gas at those similar speeds. It really is a pulsing or humming cadence you can hear and feel through the pedal.
NJ2020
Twin Cities
I commented on your Facebook post but does it change if you switch between 4a vs 2wd? If so it definitely sounds like the recent IWE issues people are seeing
Nood1es
Madison, WI
4A for me makes it more noticeable and worse. Dealer put some kind of tool that can give a rough estimate where the vibration is coming from n they have it narrowed down to the front.
Waiting on a ford field rep to check it out.
BoostCreep
SoCal
What speeds do you feel it?
