GEN 2 Ford Raptor 2018 Maintenance
Raptorjark
kuwait
Good Day All
I bought ford raptor 2018 run 110k miles
I feel it's exhausted and low performance
What do you recommend to change from engine and front steering parts and do maintenance
Additional notes :
When I ride move the steering wheel totally left only I feel some sound some errors comes out
Please advise
FordTechOne
Detroit
What’s the history on the truck? What octane are you using? The front end needs to be diagnosed to determine what is worn before replacing parts.
R
Raptorjark
kuwait
I dont know about the history exactly so what I need if I dont know about the history what should I change
I use 95 octane
What do you mean by front end and how can be diagnosed
R
Raptorjark
kuwait
I use 95 octane
This the errors I have
What do you recommend and what should I do
FordTechOne
Detroit
I use 95 octane
None of those DTCs are related to engine performance; some may be erroneous. You’ll want to clear them all out and re-evaluate to see whether any DTCs return.
As far as the history, do you know if the truck was properly maintained? Was it damaged at some point? The steering gear failure code and loose/damaged suspension parts are a good indication of prior damage.
R
Raptorjark
kuwait
It was with someone not maintain the car properly
Yes there was accident from front side
What do you think my plan with those codes
FordTechOne
Detroit
Clear them out, re-scan, and see what returns. Is the power steering working?
Nex
RIP CoronaRaptor
Washington State
Change all of the fluids and spark plugs to start. As FTO said, clear the codes and retest. Look for loose or worn bushings and replace as necessary.
Post up a picture of your truck out there in Kuwait.
