First GEN raptor, front shock spacer seized on bolt
cgriffin602
Santa Maria
I’m helping a buddy out and removing his front shocks for him the driver side lower bolt for the front came out just fine passenger side not so much. The spacer is seized onto the bolt. I’ve tried to heat it up and have used lots of WD-40 and have had no luck am I missing something? I’m at the point of cutting it out and replacing it. Does anyone know what the term is so I can order some? I have not found any online.
  • IMG_4486.mov
    15.9 MB
downforce137
In Diana
id try a ball joint press to try pushing the bolt thru..
something like this:
i had to do this on lower control arm bolts that were seized to the control arm bushings..
the spacer is usually called a misalignment spacer.. are these the OEM shocks or and upgraded one?
downforce137
In Diana
nah the shocks come with the spacers. the oem shock is a large bushing, and all the aftermarket race shocks use rod end/heims and misalignments..
id imagine easily sourced from icon
