Ebay intercooler
Space Ghost
FL
I stand corrected I don't know why I had IATs in my head when I typed that. I am gonna play around with the Torque Pro app and see what it monitors. I will edit my original post.
What youre thinkin is IAT2s, which are also the charge temps
sc85fiero
North Port FL
Not quite the same, the IAT2 is built in to the MAP sensor, located at the back of the intake manifold. It measures air temperature after the charge air cooler sure, but its also after the throttle so there is some cooling effect after going through an air flow restriction so its not a great measure for charged air temperature or the effect of a different intercooler.
-Joe
Space Ghost
FL
-Joe
interesting, always thought they were the same, thanks for clarifying.
Lunnzz19
Lunnzz19
Navarre FL
Well I can only measure and log a certain amount of parameters using the Torque app. I set it up last night to log IAT2 & charge air temp. So I just went outside and did a short log with the truck ideling and it seems it can't measure charge air temp it was worth a shot.
LeadFootSFL
FL
Random question about the torque app, is it still available and what OBD adapter are you using to get the data from the truck? iphone or android?
