Do you have to remove the Whipple to replace the 16 spark plug's in GEN 1 6.2L Raptor?
Tommysyko
Bay Area, CA
I need to replace my coils as a couple are arcing. Does the arcing cause any damage that should be extremely concerning or is it kinda get to it when you can?
That part I do not know. I've just been trying to sort out my misfire issues and this was on the list for maintenance and a possible issue.
How did you find out your coils are arcing? Check engine?
Tommysyko
Bay Area, CA
The intake tube and throttle body had to come out to access the 5 cylinder coil/plug. Some of the pills wouldn't come out due to corrosion. I had to swap the new coil pills with the 0 ohm pills from he Granatelli wires. As mentioned otherwise, tools were clutch (I needed double X extended pliers to reach one of the lower plugs).
MFNG
Illinois
No, I haven’t had any CEL, but I haven’t plugged it in to check for codes either.
I heard a ticking and searching here helped me track down the possible arcing issue. I ended up taking a video at night and that’s how I found out it was arcing.
