Deiveshaft/rear end clunk
Wilson
South Dakota
I think it helps to put my truck in to neutral before putting into park when on a slight incline letting is roll a bit before putting it into park so not as much pressure on what ever the pressure is on let me know if it helps or if I'm nut's
Squatting Dog
Squatting Dog
Kansas City, MO
Great advice... Just tried it... Put the truck in neutral, then applied e brake, then park... No clunk/bang! Thank you!
-Greg
swoop1156
USA
I never park on an incline without going to neutral and then applying the parking brake and then going to park.
Wilson
South Dakota
I never apply the parking brake and have never had a problem maybe I would if it is more than 2% grade I might think about it that is the nice thing about thees trucks I park on a 1% grade all the time wish it was flat but what do you do I like that app so now I know.
Rubare
Alexandria,VA
i encounter similar issues, it usually happened when changing gear from drive to reverse(parking usually) there is a series of clicks and ticking sound coming from the tranny/rear diff.. i cant pint point it, i was thinking about taking to the stealership to hear their response but more than likely they will give me some ******** response. Does anyone have any idea of what could that be?
Yukon Joe
Trafford, PA
I've heard this before. When you are backing up, are you turning? SCAB or SCREW? What year? I think there is a tsb for this.
Yukon Joe
www.RUNRAPTORRUN.com
Palerider
Little belated on the response but I'm just now starting to notice this on my 2012 SCREW. I've been doing some research and found a lot of people say it's the driveshaft slip yoke needing grease. There's even a YouTube video showing it in good detail. I'm going to ask around and see if an aftermarket driveshaft, like the one offered by JDM Engineering, will solve this.
