Burger Motorsports
Nick@Apollo-Optics
I'm not sure if Sean is a member of FRF, but I did send him a link to pop in and provide his feedback. But here is some of his feedback on his 2023. We did full bolt-ons on his truck with the JB4. He's been running this for about a year now. COBB intake, K&N Boost Tubes, COBB Intercooler, Turbosmart BOV, SPD Thermostat, Ford Performance Spark Plugs, and SPD Downpipes. I've got a couple screenshots of his reviews on the setup.
Here's a link to the site with full info on the JB4: https://apollo-optics.com/products/f-150-ecoboost-raptor-jb4
bigdave18629
Live in Nor Cal, looking for feedback on tuner only, plus want to preserve warranty.
MORaptor1
SW Missouri
That’s great…..but need some #’s right?
Nick@Apollo-Optics
The JB4 has a CARB compliant version, so your'e good to go. Dyno charts below.
Well, y'all said real world feedback so I figured I'd send over some feedback from one of our customers haha. But here is dyno charts from 5 Star Tuning. 4 Runs: Stock, Map 1, Map 2, and Map 3.
Stock: 384.8 WHP, 448.3 LB-FT
JB4 Level 1: 416 WHP, 505.7 LB-FT
JB4 Level 2: 428.1 WHP, 504.6 LB-FT
JB4 Level 3: 438.5 WHP, 516.7 LB-FT
Map Notes:
Map0: Fully disable JB4
Map1: +3.5psi peak over stock, default map, 91+ octane
Map2: +3.5psi peak, less top end taper, more aggressive version of map1.
Map3: +4psi peak, suggested for 93+ octane and/or modified trucks
bigdave18629
Thanks for posting, just added power steps from you, but didn't put in the OBD port splitter. Do you know if it will work through the splitter is I put one in?
Nick@Apollo-Optics
I believe that it will as the OBD2 sensor is used for monitoring. I will check with Burger and see if there is a particular splitter that they recommend for this.
Johnny@Apollo-Optics
TX
Is burger tuning 2024 like were with 2023 yet?
Any 2024 tuning or performance mods at all yet?
Theres a few 2024 performance mods. All cold air intakes will work on the 24s, as well as the SPD Downpipes have confirmed fitment.
Im 99% sure the JB4 will work on the 24s and we will confirm it here shortly I believe.
Happy to help you out if you need anything for your new truck!
MORaptor1
SW Missouri
So i got my JB4 yesterday.....and would like to try the E30 mix. Do i run map 4 or 5 for e30? Guess map 3 is just the lowest power E30 ok map? And how exact does the fuel mix need to be? My math says just under 3/4 tank of 91 octane is the time to fill up nearly 10 gallons of E85. That correct? Then from there its always 2.75/1 premium/e85.
MORaptor1
SW Missouri
The JB4 most certainly works. Starting map 3 on the V3 it hauls ass. I’m running E30 mix on 4 and no issues on my 23’ so far. It boogies. Definitely the way it should have come. Map 1 is noticeable, but worth skipping if you have 93 or E30.
