Bed bolts spinning
Steebo
Colorado
My left middle bed bolt likes to spin even with the nut and clip in the proper location. Ended up using a rubber mallet, couple medium wacks and she was able to thread.
Edit: btw the original bed bolts are 1 time use. Should be replacing them every time you take off your rack. Highly recommend upgrading to khc bolts
MAMiller44
Tampa, FL
The problem is that the nut/clip combined piece of hardware is also technically a “one time use” piece. The nut breaks off the clip. This is what I was referring to earlier where you need a real thin wrench to wedge in there and you can grab just the nut from underneath when this happens.
ocbcwc
Huntington Beach
Bringing this thread back to life. I have a rear bed bolt that I am trying to take out. It just spins and I have tried a wrench from underneath, it feels as if the nut is rounded. Trying to take off to install some bed supports. Any suggestions?
Chiefapple
Milwaukee, WI
I'ver never looked underneath, but I know I have one that spins. Was swapping them out to put KHC bolts in. I'll have to figure it out soon though.
dsiggi
Detroit
KHC bolts are a recipe for terrible galvanic corrosion, I would not use them with the OEM nuts. Also those grade 8 bolts are terrible when it comes to corrosion protection compared to factory.
MAMiller44
Tampa, FL
Anybody figure out how to capture a spinning bed-bolt? I've got a middle bolt that is spinning and the nut feels rounded off.
downforce137
In Diana
vise grips... its a two person job.
on one of mine center ones the little clips on the frame broke off .
you can access all 4 nut clips without removing the bed, and the front two are welded to the frame
Psirus7
Eastern Washington
Thanks. I've fully rounded off the nut on one of the centers. I'm thinking about running a spot weld on the nut to the plate to getting it to stop spinning.
