Add USB C plug/module
ljn21
Tega Cay, SC
I could swear saw somewhere that I cant find now, about changing the USB module to have one of the ports be a USB-C plug. Anyone know if this is possible and what the part number is?
L
ljn21
Tega Cay, SC
Thx, that looks like an aftermarket module and the oe numbers they list dont lead to the same ford part from the pictures? What I see through google shows either one usb plug or two usb olugs but not 1 usb + 1 usb c
CHMP
Santa Cruz
I have it installed and it did the trick from a convenience perspective. Now I don't have a full on charger plugged into the standard outlet on the dash. A couple things that could be better: 1. Wish there was a module out there with two type-c plugs instead of one. 2. Even though my pixel 3 XL says it's charging rapidly when plugged into the type-c outlet, it definitely isn't. It charges at the standard rate, not a huge deal but wish it did rapid charge.
MDJAK
NY
How hard is the install? And what is the advantage if it doesn’t rapid charge? I always have my phone plugged in so don’t need rapid anyway.
MDJAK
NY
Not what you were looking for, but I thought I'd post this for anyone looking for options in the future. I recently replaced the cigarette lighter in the center console of my Z with this:
https://www.amazon.com/gp/product/B07JPJTKCC/?tag=fordraptorforum-20
I rarely use the 12V socket for anything other than USB chargers anymore, so I figured this was better.
I like that. Ez install? Did u have to remove cover to close OEM cover? I never have OEM cover closed anyway. Mine actually stopped working recently. Annoying.
sixshooter_45
Arnold
