24 Sport Mode engaging 4wd?
ashleyg
Just picked up my 24 R…. When I switch to sport mode it engages 4 wheel drive automatically.
Anyone see this before? My 21 Raptor stays in 2nd.
cheek
All you have to do is while in sport push 2nd then save that for your R setting.
Xiaofeng Mu
CA
V8 has more power and has to use all 4 tires to put torque on ground. V6 doesn’t and uses 2wd to reduce powertrain loss. 4A on dry road is totally fine as long as you don’t go super tight turn.
Unless at stop light I will use 2wd on R for sport mode. 4A has tons of torque steering due to missing torsen front diff.
MZRaptor72
Cincinnati
I believe the Torsen produced the torque steer…
cr23raptor1983
Baltimore, Maryland
Mine did this as well. Until about 25 miles into the odometer- it stayed in 2wd when going to sport mode.. weird I know, jas worked fine ever since (truck has 3,800ish miles).
