2013-2014 Raptors Sync 2 -> Sync 3 Upgrade
Stormtrooper
Raptor R
Huntington Beach, CA
I wish I saw your truck for sale before it sold. I would have scooped it up.
It was definitely a gem! This was her build list at the time of sale:
2014 Ford SVT Roush Raptor with 700HP
OVER $50K Invested in Upgrades!
- Roush Supercharger, Phase 2 with JDM 700HP Upgrade!
- Ford Racing's twin 65 mm billet throttle body
- Griptec 72mm supercharger pulley
- SCT X4 Programmer w/ JDM Custom Tune
- TSS Billet Oil Pump Gears
- Sync 3 Upgrade - Apple CarPlay (Same Tech as Gen 2)
- Gen 2 OEM Steering Wheel - Paddle Shifters!!!
- Custom Two Piece Steel Drive Shaft
- Custom 4-Wheel Drive Steel Drive Shaft
- RPG Stage 4+ Kit
- RPG Billet Tie Rod Kit (Black)
- RPG Billet Upper Control Arms (Black)
- RPG Billet Rear Traction Bars (Black)
- RPG Rear Frame Support
- RPG Billet +2” Shackles (Black)
- Deaver +3 Leaf Springs
- Fox 3.0 DSC Adjustable Front Internal Bypass w/ Coil
- Fox 3.0 External Bypass Rear Kit
- Fox Air-Bump 2.5
- Pinch Welds Removed by RPG
- RPG Trophy Truck Front Bumper
- Baja Designs ARC Dual Control 40” Amber/White LED Light Bar
- RPG Rear Bumper with Motion Sensors & Baja Designs S2PRO Amber Lights
- GJ 3rd Brake Light with NMO Mount With Baja Design S2PRO’s Amber Sides/White Center
- Dovetailed Rear Fenders done by RPG
- (5) Method NV Wheels - Matte Black, 17 x 8.5 0 Offset
- NEW BFG All Terrain 37 x 12.5 - 17 (Installed within the last 2000 miles)
- RPG Custom Fab Work to accommodate 37" spare tire under the bed
- RPG Trailer Hitch Receiver
- Exhaust Turn Down’s done by RPG
- Smoked Lens Red LED Rear Bumper Tailgate Sidemarker Lights
- Smoked Lens Amber LED Front Grille and Fender Sidemarker Lights
- Custom Painted Smoked OEM Taillights with LED Reverse Light
- Ceramic Window & Windshield Tint - Last Month
- Ceramic Paint Treatment - Last Month
- Blacked Out Ford, Raptor & 6.2 Emblems
Services & Parts Installed Within the Last 1000 Miles:
- Odyssey 65-PC1750T Battery
- StopTech Front & Rear Brake Pads
- StopTech Front & Rear Cryo-Treated Rotors
- Custom Stainless Steel Brake Lines
- Break Fluid Service
- NGK Iridium IX 6510 Spark Plugs
- Gates K061251 Serpentine Belt
- Front Differential Fluid Service
- Rear Differential Fluid Service
Services & Parts Installed Within the Last 100 Miles: (Over $10k invested in updating and upgrading the cooling and power steering system):
- CBR Oversized Radiator w/55mm Core
- Upper & Lower Radiator Hose (Ford OEM)
- Heater Core Hoses Replaced (Ford OEM)
- AFCO Oversized Super Charger Cooler with Dual 10” SPAL Fans (Black)
- Lee Power Steering Pump Kit with Custom Oversized 10” Resevoir Tank
- Intermediate Steering Shaft (Ford OEM)
- CV Axles (Ford OEM)
- Front Hubs (Ford OEM)
- Rack & Pinion (Ford OEM)
- RCV IWE Delete
- Mag-Hytec Oversized Transmission Pan & Filter
- Custom 20 Row Oversized Transmission Cooler
- Transmission Fluid Service
- Transfer Case Fluid Service
Most recent upgrade $2000 Value
- OEM Gen 2 Steering Wheel Conversion, Paddle Shifters & All Media Buttons Work!
LARAPTOR62
Los Angeles
So whats the consensus on this?
Kit can be had for under $800 through ebay or some guy named carlos on facebook (what if I don't have facebook?).
AC and HEATED seat functions work. Rear camera works. Steering wheel controls work. Front camera only works below 5 mph, and if rear camera delay is engaged.
Anyone have any major issues with battery draw or AC not working right? I read a couple posts about that
rkneeshaw
Northern Michigan
I'm happy with the Sync3 overall.
Outstanding issues I have with it are as follows:
* Heating up the cab/fan speed seems off at times, like truck doesnt know its cold and needs to turn up the heat. I can't prove this yet though.
* Occasionally the radio defaults to Off when I start the truck. Its random, and I can't pin it down. Could be a bug in the software version I'm on?
I programmed it myself, so its possible my coding/programming isn't perfect yet, and I need to consult with some of the pros who sell the kit to confirm.
Regardless of all this, I'd still do the upgrade again, its much better than the old sync 2 system. Slightly quicker, easier on the eyes, simpler to use.
griford
Sweet! Now get you a cplay2air and you’ll have wireless CarPlay!
any chance you can let me have a copy of your apim programming? I get my nav to work, but the time wont update, change settings and then the nav works and the times does not.
BalanBro
I got a Sync 3 upgrade from a guy I found in one of the Facebook Raptor groups. 100% good to go and is a true plug and play. Totally satisfied with it and is good to go in my book.
https://foursynctech.com/products/2...CfLZhSA0RiIB_jVS2ugefQTfAWx2Ouov2Nr5uK7w7bPug
Yup, I am one of his customers too. Anthony Callegari I think was his name. Really great dude with fantastic after sale customer service. He'll answer any questions you may have. Also, always great to deal with a US seller.
AZEngineer
Phoenix AZ Area
I have a 2013 SCAB I purchased new May 2013. 83,500 miles in rust free AZ :)
I just upgraded from the OEM Sync2 to a the Sync 3 with a Sync 4 HD Screen. So far it looks great but waiting for the wireless Carplay adaptor.
I had to replace the OEM Backup camera last year and I used one from Camera Source. It's much sharper with better contract and better in low light.
Now that I have a much newer sync system, is it possible to get a camera with moving grid lines that replaces the OEM in the tailgate emblem ?
Update, I didn't realize when that post upgrade the front camera doesn't work unless you add a delay setting to the rear camera. I need to try it. not sure why this can't be resolved to work correctly.
