Wolo air horn kit install!
Cody Templeton
Des Moines, IA
Was wanting something to replace the stock horns since they're a bit too quiet. Was thinking of going with the Hella Supertones, but also had been looking at air horns. Came up with this Wolo air horn kit locally. Came with everything in it including the compressor, air horns, mounting hardware, line, and fittings. Just had to drill a hole to mount the compressor, cut the stock horn connector off and install spade terminals, and the horns bolted up to the stock horn bracket perfectly. I also painted the horn bracket while it was off to freshen it up. Kit fits perfect and works great!
Very similar to the Marco kit I got a couple years back. I scored 118db 10 feet in front of the truck. Stock was something like 92db or similar.
Much improved over stock, no question.
C
Cody Templeton
Des Moines, IA
