upgraded the B&O not so unleashed.
greatone99
ma
Well i had to bite the bullet and upgrade my not so B&O system. I guess the final straw came when i took my wifes Nissan Rouge for a ride and the system sounded much better then mine;(... I ended up having the following installed.
Focal K2 power EC165K(front) tweets
Focal Flax(rears)
Stealth box with two 12" subs
Alpine HDA-F60
Alpine HDA-M80
Nav-TV
Dynamat fronts rears backs
WOW... It sounds amazing with the right material playing.
how many channels r u running . this was my 2019 ,I just picked up a 23 ,my 19 had 5 channels fully active fronts no rears and 2-10 inch subs ,I was also running front kx2 focals. thinking of doing this to my 23 .
freddyttt
freddyttt
NJ
goblues38
STL
Focal Flax(rears)
Alpine HDA-F60
Alpine HDA-M80
Nav-TV
good job doing it right and not trying to cheap out by omitting the NAV-TV
Renomaan
Does the factory system already have amps back there?
If not, then I assume you took the rca feeds from the OEM head unit?
HighwaySentinel
︻デ┳═ー - - - - - - -
California
Factory B&O has an "amp" in the rear. It is not as easy as taking RCA feed from the OEM head unit. NAV-TV Zen module is the proper way to get the signal to your aftermarket amplifier(s).
WTX
The Permian Basin
But the subs are apparently under the flip up seat? I’m just wondering for myself if there’s a solution to put one lone sub behind the seat. I know JL Audio makes some slim 10’s I had behind the rear seat in my Tundra a few years ago.
Just had this installed in my truck. Perfect fit just lost jack space.
