Upfitter #2 BD S8 30 Fuse Blowing
OEMPlus Raptor
OEM preferred....
Oxnard CA
Hey guys, I've taken my truck out a couple times and this past weekend it happened again. I have my BD S8 behind the grill light bar wired to switch number 2 (15a) and I keep blowing the fuse. I'm going to check ground, but the weather pack connector is tight and not sure what else could be causing it? It's happened twice while off-roading and having it on.
Thanks, any input would be appreciated.
greatone99
ma
y would a relay change the amp draw . a relay is just used when u r trying to isolate voltages . and as a switch
The inline fuse in the wiring harness or the up fitter fuse?
You’ve gotten some good suggestions already, but before throwing a relay at it, I’d test to see if there’s a short. If you wire pos. directly to the battery, does the inline fuse pop?
What do the wires look like- inspect from the light to the connection points.
How are the connections?
If everything checks out, you have good crimps, no severe bends in the wiring, etc. a relay is probably a good idea. Maybe not technically “required” but probably better overall.
