Terribly loud boom and white noise
Jimandaim
Penna.
Welll....at the suggested post to have update on my 22 , to fix the loud boom and hiss.....update was done......dealer wants to hear it......never happens there at dealer...go figure.....
Still does after update...
.try to capture on recorder......but u know how that works!!!!!
Any more suggestions??????
Open to anything.....I do know others have had this with B&O 18 spkr system....
Welcome to FRF, N00b.
Pictures, or it’s a prius.
Hang a go pro from the windshield if you don’t already have one. Power it with a tap from the roof console wiring, and adapter to mini or micro usb - whatever port that is.
Drive while recording. When it happens, stop the recording to save it and start a new one. If you run out of space while recording, sometimes it corrupts the file.
Download and take to the stealership.
HighwaySentinel
︻デ┳═ー - - - - - - -
California
It looks like you have had the update done. Have you checked all of your fuses to make sure they are seated. The fuse for the amp can be a cause. Also, how's your battery?
is that where the boom comes from, the amp?
This would make sense. I had to disable auto stop/start completely because of a similar issue on my ’17. I upgraded the amps and at low volume it was ok. but, if it’s just me in the truck, volume is usually a little higher and I noticed the amps would scram and sometimes POP loudly. No bueno. Or at least it sounded no bueno. I put a volt meter on there and that was pretty easy, I was seeing 8.8 to 9.2 volts while start up was going on.
HighwaySentinel
︻デ┳═ー - - - - - - -
California
While I have not experienced it myself, I once again used our hidden search feature to bring up something that I had remembered reading in the past. In one of the threads, the three items for fix included update, fuse, and battery. Who knows for sure though.
