Svc uca and tie rods instal question
LambSVT
California
I installed svc uca and full tie rods on my gen1 and it squeaks when I turn 1-8 degrees . Is this normal with upgraded hardware? I also run king 3.0 finned shocks .
How do I stop the squeaking ? Or is this normal ? I added dry lube to areas and it stopped until it rained. Any help would be appreciated.
IDI-Charlie
Staunton, VA
The squeaking is normal, lube em up regularly and it'll help keep it down as well as prolong their life. I did mine every oil change, though I had boots on the rod ends to help keep the water out.
LambSVT
LambSVT
California
What kind of boots did you run as these oem ones where too small to fit the svc rods.
IDI-Charlie
Staunton, VA
Tie rod boots I ran the OEMs, you have to cut them back a bit to fit. I used worm clamps to hold them to the rack/tie rod.
For the rod ends, I used the boots for the respective size from Kartek: https://www.kartek.com/parts-categories/rod-end-boots.html
When installing you have to be careful not to rip them, recommend ordering a couple extra if you're going to put them on. Then when it's time you can wipe it off, pull the lip back a bit, and squirt the lube in. When I pulled my front end apart after about two or three seasons, everything still felt like it should with minimal wear play (save the one uniball I managed to crush the PTFE liner in with a bottom out).
LambSVT
LambSVT
California
Thank you for the link that is much appreciated!
