Kicker Sub upgrade
Toadster
Folsom, CA
you weren't grumpy at all :)
btw - if anyone else is interested, it was my sensitivity was turned down too much - got that up and dialed in the cutoff around 80-85Hz and it sounds awesome now!!!
Thanks all!
Rattpter
NorCal
So am I reading this thread correct where one install was disconnecting the stock amp & running new power from the battery for the new Kenwood 600w amp, while using the signal wire from stock amp to turn on the new amp?
The other option was disconnecting the stock amp power to feed the new Kenwood amp power?
Apology as this is a pretty old thread and there were a few different options from the beginning, also using a LC2i unit(sounds like this may not be needed in later models?)
Thanks in advance as this looks like a pretty simple, low cost sound upgrade. The stock B&O is not bad, but could definitely use a little help while not losing floor space.
2020 Gen2
Toadster
Folsom, CA
I used a new power feed to the Kenwood amp, and used the existing L/R channels from the stock amp
the Kenwood amp is auto-sensing and doesn't need a signal wire - as soon as audio hits the L/R channel, the amp turns on
it's been a great addition, much better sound, the fiberfill and wrapping the sub box made for a richer bass sound without the hollow/plastic tunnel sounds...
https://2017-ford-raptor.blogspot.com/2023/09/
Rattpter
NorCal
Thanks man! I took a look at the link to your blog also, great detailed information. I'm interested in the Whipple stage 1 kit, how's your daily mileage affected?
aknight55
new hampshire
Do you get the 2 ohm or 4 ohm if you want to run this off the factory amp? Also have an 2018 801A any issues with start/ stop I have been reading about? Thank you
Toadster
Folsom, CA
Any suggestions if I don’t have a 3d printed spacer?
you can get MDF or plastic ring spacers on amazon
Universal MDF Constructed Spacer for 8 Inch Speaker or Sub - Adds 3/4" To Depth
I got the 4 ohm woofer to match up with my amp, the 2Ohm would have pushed my amp into 1Ohm mode (unstable), so I have 200W - but it's MUCH improved over stock
no issues with start/stop because I ran power from the battery to the amp directly, audio feed from the existing amplifier
