how to remove rear c pillar
downforce137
In Diana
pull the weatherstrip, unbolt seat belt and i think theres one other screw but theres just some clips into the body
G
greatone99
ma
I got that far ,im trying to replace it ,I need to separate the seat belt somehow ,as it feeds thru the panel
hpschrank
Florida
Sounds Good Audio in Nashville has an install video on their website of an amp rack behind rear seat in a Gen 2. In order to do this they show you how to remove C pillar and disconnect the seat belt/air bag mechanism on the belt.
Julian Rivera
OREGON
it is easy. the Sounds Good Stereo video will show you.
The seat belt has to be taken apart. small plastic clip hides the bolt. I think it was 12mm. then you can just pop the panel out. there is a small little twist "T" shaped safety cable at the top of the panel to keep it in place when the airbag goes off. that needs to be twisted and pulled out to release the panel.
