Gen 2 Raptor Vacuum System
New recaros
Colorado
I posted in another IWE thread the proper vacuum strategy.
Short version.
Above 32, hubs stay engaged (no vacuum) for 1/2 mile after start
Below 32, it is 1 or 2 miles. This is to warm up the front differential.
What, you say ford designed it so the hubs stay engaged? Not sure I buy this one
mobilefordtechjosh
Northern Virginia
The Hubs holding vacuum disengages the shaft ends when you loose vacuum it will engage the ends. Make sure your testing the correct position on the IWE and when applying vacuum see if it stays steady and also on jack stands spin the wheel while it’s holding Vacuum see if it changes.
New recaros
Colorado
So the truck opens a solenoid valve after a certain distance. Well how do you test it? Your in a shop, going nowhere and could not disengage or spin the wheel.
isis
PA
If you’re in a shop I hope the temperature is above 32F.
New recaros
Colorado
You just don’t get it. You shut the truck off and doing anything, then you need another half mile. Know wonder all/most techs are air heads, they leave the truck running after driving it around the block. Ford is gassing our tech’s
