jessie5150
Looking for some insight on these dam shocks . Came across many threads and no one seems to have a answer .
Installed some fox 3.0 on my gen 1 . Have the clunk/metallic sound as if something is loose in the front end . At any speed going over cracks/expansion joints . Speed bumps or anything that makes the shock cycle fast .bumpy uneven roads etc. But over big bumps nothing . Only over small stuff .
Checked and torqued everything . Tried chasing it down. Started throwing parts at. Replaced lCA bushings (stock) replaced upper control arm with oem . Replaced lower ball joint . Replaced inner and outer tie rods .replaced the lower shock mount bolt with the correct shank from KHC . Also adjusted the rack and pinion to get out any slack . Running no sway bar. So can't be that .
Shocks are brand new .have about 1000 miles . Done it since from out the box .just curious if anyone else has came across this issue or has a fix .
