- Joined
- Jul 15, 2017
- Posts
- 1,093
- Reaction score
- 985
If you want to upgrade your OEM Fogs to a higher output and better pattern, we developed a kit for that for ALL Gen 3 Raptors including the Modular Bumper.
You can also add snap on YELLOW or Black Covers. These are all in stock and available to ship right away.
SSC2 Covers
Note on the covers. We haven't tested them in this application with the SSC2's as it is a tighter fit. So you may need to space them out. However, if your goal is amber backlighting. You'll have that as a default.
SSC2 Pro and Sport Light Kits-
The SSC2 Kits will work with our plug n play harnesses and adapters to power your amber backlights. The kit has everything you need with a default to plug your backlights into a switch. Then you have the option instead to add our marker adapter to make them power like the video.
Hope this helps!
Here is a video-
John
SSC2 Covers
Stage Series Stage Series 2in LED Pod Covers SSC2, (Sold in Singles) Yellow, Clear, Smoked, or Black
Stage Series SS2 LED Pod Cover, Yellow, Clear, Smoked, or Black (Sold in Singles) Part Number: DD6599, DD6600, DD6601, DD6602 Overview. The Stage Series C2 LED Pod Cover will help keep your LED Pod clean and protected from dirt, dust, or whatever else the road throws your way. These covers are...
specialtyperformanceparts.com
SPV Parts 2021-2024 Ford F-150 & Bronco Raptor OEM Fog Light Upgrade Kit with Brackets and Diode Dynamics SSC2 Lights
Purchase a flog light upgrade kit for your 2021+ Ford Raptor online! This OEM upgrade kit includes mounting brackets and Diode Dynamics SSC2 lights.
Hope this helps!
Here is a video-
John
