6.2 intermittent valve train ticking noise at start up ??????????????
FishFreak
Sacramento, CA
FWIW most vehicles have a tick at startup, it's the lifters. Pre-oiling, such as an Accusump setup, helps with that problem. Nothing to worry about on most vehicles but it sounds like more severe issues with the last few posts :(
Does anyone have experience using an Accusump on our 6.2L engines? Mine makes a little clatter on startup and it goes away quick. Would the preluber just hide the symptom and not fix the problem; excessive valvetrain lash as FordTechOne said?
FordTechOne
Detroit
Yes, that world be a band aid for the actual issue. Clatter on startup can be lash adjusters or a failed cam phaser. It can also be caused by a faulty anti-drainback valve within the oil filter. I’d start there.
FishFreak
Sacramento, CA
e-30 94 octane
Lol, not available on the Left coast ;)! It's not pinging, my ear is well tuned to that sound. I'm just talkin' about the first few seconds after startup, I'm remote starting, walking up to it and I can hear it quiet down in 2-3 seconds as oil pressure builds.
FishFreak
Sacramento, CA
Needs to be torn down and have the lash adjusters replaced.
Hey FTO, if I'm in there replacing the lash adjusters, should I also do anything else, preventatively, like change the valve springs? I'm at 133k miles and I'd like to keep this truck forever, so using high quality replacement parts is key, so if you can recommend specific lash parts I'd appreciate it :cool: .
FordTechOne
Detroit
These engines have a bad habit of randomly breaking valve springs at higher mileage, so since you’re in there already it would be a good preventative repair.
FishFreak
Sacramento, CA
Is there an interference between the valves and the pistons on our engines? Is a broken valve spring usually catastrophic? Can you recommend a source or brand for high quality valve springs, and lash adjusters for that matter? I'd like to put in better ones than Ford did.....
FordTechOne
Detroit
Yes, if a valve spring breaks it will often cause the retainer to come off and the valve drops into the cylinder. That causes catastrophic engine damage.
Maybe someone here can recommend a good aftermarket upgrade from factory, I’m only familiar with the OEM parts.
EricM
OHIO
If it's 2 seconds at startup, leave it be.
6.2s go 350k miles on the regular with no internal engine work.
