2023 Gen3 37PP-steering wheel thumping/tapping feeling.
BoostCreep
SoCal
Here is the new (second replacement updated part# NL3Z-3B676-B) lower shaft after driving it home from the dealer (hot). You can see the grease where the yellow rubber is sliding on the shaft. Still thumping...
Maybe it’s not that part at this point. Is it possible you’re getting excessive movement between the cab and frame somehow? I checked out this part and mine does have movement too but I don’t get the sensation you describe while driving.
JDMCTR00
JDMCTR00
Los Angeles,CA
The thump is definitely coming from that part. That's the only thing i'm moving and it's the same sensation I get in the steering wheel. I had my friend move it just as i'm doing while I sat inside and held the steering wheel. Does yours make that thumping sound in my video(turn up your volume)? They are all supposed to move that's how they are designed. It's not supposed to bind and transmit a thumping sensation into the steering wheel. You can hear the binding in my videos.
BoostCreep
SoCal
I’m not saying it’s not that part, what I’m saying is something is causing it to move while you drive and it’s not your fingers like you’re doing manually in your videos. Maybe whatever is causing it to move while you drive is the problem, and not that part, even though the part is what’s making the noise/feeling.
JDMCTR00
JDMCTR00
Los Angeles,CA
There is always movement at that location with flex or whatever. That part should not bind under heat and cause the thump. They checked all bolts and brackets in that area for torque. Your lower shaft moves but I'm assuming it doesn't bind/thump like mine. I'm thinking about putting a GoPro down there to record it while driving.
So your lower shaft "cold" is just like my video "cold"? And yours "Hot" is like my video "Cold"? No binding noise or thump.
SurfRaptor
Newport Beach CA
I have no issues with working on the truck myself. We all paid a good amount for these trucks and shouldn't have to.
Completely agree there. I shouldn't have all these small issues that I have with the truck too. I've been letting the dealer handle it and for the first time ever I got the extended warranty when it was reasonable from Ziegler. Dealer is stuck with me for 8yr/150k lol
BoostCreep
SoCal
So lower shaft "cold" is just like my video "cold"? And yours "Hot" is like my video "Cold"? No binding noise or thump.
In all honesty I didn’t check cold vs hot. Also I think I felt what you’re describing maybe 5 times in the first 50 miles, my truck has 90 miles on it now. It sounds like a tolerance issue and yours isn’t “breaking in” within the allowable tolerance. Not sure why you’ve had several bad ones though.
JDMCTR00
JDMCTR00
Los Angeles,CA
Yes, it sure seems like a tolerance issue. I had to figure out the issue myself and document it with videos. It's very clear where and what the issue is.
GCATX
King Dingaling
Central Texas
So what is the next step?
I hate going to the dealer. I'd probably try and pump some grease behind the yellow seal, on all sides and see what happens.
If that makes it quiet I would consider installing a zerk on the larger shaft and repeating if the knock comes back later on.
Just throwing out ideas.
JDMCTR00
JDMCTR00
Los Angeles,CA
They need to send down a Ford field service engineer. The new shaft has grease on that yellow boot. This was the "new" part number.
