This is a one-part video of a 2022 Ford F-250 Shelby Super Baja we just completed for a complete high-end Focal Utopia M custom stereo system upgrade. This video is an overview of the work we did to upgrade this truck. From custom enclosures to custom A-Pillars, these trucks have some of the best gear available. You can also purchase many of the products we use in our installations below.
*****Equipment List:*****
Ship your Truck to our facility for this upgrade
Our Complete Plug & Play Packages shipped to your door
--Custom Subwoofer Enclosure for the Ford Trucks
--Custom 3-Way A-Pillars
--Speaker Adapter Plates for the Ford Trucks (8-inch and 6.5-inch)
--Door Baffle Block Off Plates
-- SQL Audio Multi-Layer Sound Treatment (Used one bulk kit for front & rear doors)
- Blackhole Tiles - 2- Boxes (144 Pieces)
--Amplifier Mounting board
--Full-Length Custom Made Power Harness
--Front Speakers
Focal Utopia M (8-inch, 3.5-inch, TBM Tweeter)
-- Center Channel
Illusion Audio Carbon C3CX 3" SQ Audiophile Coaxial Speaker Kit
--Rear Speakers
Focal PC165FE Flax EVO Series 6.5-inch 2-Way Coaxial Speaker Kit
--OEM Signal Integration
Nav-TV ZEN-A2B / DSP12A-A2B
--Speaker Wire Integration
Pac Audio APH-FD02 Speaker Connection Harness
- Front 3-way Amplifiers
Two Mosconi Pro Series 5/30 5ch Sound Quality Audiophile Grade Amplifier
- Rear Speaker + Center Channel Speaker Amplifier
Mosconi Pro Series Pro 410 4-Channel
- Subwoofer Amplifier
Mosconi Pro Series Pro 110 1-Channel
--Digital Sound Processor for Tuning
Mosconi 8to12 Aerospace
--Subwoofers
Focal E25KX High-Performance K2 Power Series 10-inch Subwoofer
All of the tuning, installation, and fabrication are done by our team. Learn about us at
Sounds Good Stereo
Mount Juliet, TN 37122
Contact Us
We offer a wide selection of custom stereo upgrades for your Ford F-150, Super-Duty, Toyota Tundra, GMC Sierra, Chevrolet Silverado, RAM TRX, Ford Bronco, Ford Mustang and many more vehicles.
soundsgoodstereo.com
2009-2024 Ford F-Series SuperCrew Truck Custom Level 5 Subwoofer Enclosure Box (Including Raptor)
Are you looking for the ultimate Ford F-Series Custom Subwoofer enclosure? Not only does this enclosure look amazing, but it's also designed to deliver the best sound quality, output, and low-end extension that you won't find in other F-Series enclosures. Any questions, please let us know...
Hand-Crafted Custom Made 3-Way A-Pillars for 2015-2020 F-150 and 2017-2022 SuperDuty Ford Trucks
Are you looking for the ultimate Ford A-Pillars for your 3-way component speaker kit? If so, we have a unique, hand-made set for your truck. Includes: - New Ford OEM set of pillars & handles (No need to send yours in) - Custom Built 3-Way provision that will fit most mid-range tweeter...
Custom Made Speaker Adapters for High-End Installations - Compatible with 2015-2023 Ford F-Series Trucks, Expedition and Many More Vehicles
Are you looking to upgrade your truck from the factory 6x9-inch speakers to an 8-inch, 6.5-inch, or 6x9-inch aftermarket speaker? We have the perfect solution for those that want a rock-solid mounting platform for their new speaker system. These are not the cheap, flimsy speaker adapters you...
Custom Made Door Access Block Off Plates - Compatible with SuperCrew (SCREW) 2015-2020 Ford F-150 + 2017-2022 Super Duty
Are you looking to build the ultimate enclosure in your door panel? If so, these block-off access plates will improve your mid-bass performance and deliver the sound you're looking for.- Hand-made here at our facility just outside of Nashville, TN- Available for the front doors & rear doors- Use...
SQL Audio Soundmat (Bulk Pack - 55sqft - 10 Sheets per box)
10 x SQL Audio Soundmat Sound Treatment (Per Sheet - 5.5sqft)
Blackhole Tile Coated Water Resistant Multi-layer High Efficiency Acoustical Absorption Pads
Available in multiple quantities packages, choose what best fits your needs below. Each individual tile is 4” x 3” x 1.5” A coated water-resistant multi-layer high-efficiency acoustical absorption pad with a pressure-sensitive adhesive back. USE Ideal damping for enclosures exposed to the...
Custom Made Amplifier Rack/Plate/Board - Compatible with 2015-2024 Ford F-Series Truck
Looking for a secure place to mount your aftermarket stereo equipment in your 2015+ Ford F-Series SuperCrew/SuperCab Truck? If so, we have the perfect solution.Custom-made by our team out of premium HDPE which provides a strong, stable platform for your gear. This mounting system uses factory...
Full Length Power and Ground Power Cable Kit (Designed for 2015+ Vehicles)
-20' Power Copper Wire (dressed in Tech flex)-20' Ground Coppe Wire (dressed in Tech flex)-Littelfuse OEM Style MEGA fuse holder and 150a fuse-4 1/0g 5/16th's ring terminals-2 1/0ga Glands/Grommets-10 8" Tie Wraps
--Front Speakers
Search: 30 results found for "Focal Utopia M"
-- Center Channel
Illusion Audio Carbon C3CX 3" SQ Audiophile Coaxial Speaker Kit (Each)
Illusion Audio Carbon C3CX 3" SQ Audiophile Coaxial Speaker Kit To develop this new Illusion Audio speaker line we combined our decades of experience manufacturing high-end audiophile speakers with our passion for maximum performance mobile audio. The development process covered several years...
--Rear Speakers
Equipped with the Flax cone, the woofers from the PC 165 FE kit deliver a very dynamic, natural sound without colouration. In addition, the TMD (Tuned Mass Damper) surround they incorporate stabilises the surround to achieve better control, and even greater neutrality and linearity.The...
Factory B&O Including Unleashed Factory Stereo Interface for Complete Upgrades - Nav-TV ZEN-A2B
The Nav-TV ZEN-AUDIO DSP6A-A2B processor seamlessly converts 2018+ Ford factory A²B® (Automotive Audio Bus) to 6-channel analog RCA and TOSLink output. Adding aftermarket amplifiers to the OE B&O or Revel amplified SYNC3 system has never been so simple. This module integrates directly with the...
Pac Audio APH-FD02 Speaker Connection Harness - Compatible with 2018-2023 Ford w/B&O Amplified System
Simplify your amplifier installation with the AmpPRO Speaker Connection Harness. The AmpPRO Harness (APH) enables you to simply plug into the factory speaker wiring harness, avoiding cutting the original wiring or running aftermarket speaker wires throughout the vehicle. Easily feed your...
Mosconi Pro Series Pro 530 5ch Sound Quality Audiophile Grade Amplifier
FEATURES: 5 channel amplifier Available in Black/Silver finishing SPECIFICATIONS: Low Pass Filter 40-220 Hz Target Powers 95×2 + 185×2 + 660×1 Watt @ 4 Ohm 150×2 + 290×2 + 1030×1 Watt @ 2 Ohm Input Sensitivity (Power rating ref) 0.35V ÷ 12V (5.3V in DDSP mode) [CH1/2/3/4] 0.14V ÷ 5.9V (3.1V in...
Mosconi Pro Series Pro 410 4ch Sound Quality Audiophile Grade Amplifier
FEATURES: 4 channel amplifier Available in Black/Silver finishing Power Rating: 120 Watt per channel @ 4 Ohm < 1% THD+N Sn Ratio: > 74 dBA / >95 dBA (DDSP) (ref: 1 Watt into 4 Ohm) Click here to download the Specifications (*) VERY IMPORTANT NOTE – READ CAREFULLY4 Ohm ST or 8 Ohm BTL –...
Mosconi Pro Series Pro 110 1ch Sound Quality Audiophile Grade Amplifier
FEATURES: Single-channel Full Range Class D amplifier Available in Black/Silver finishing Power Rating: 670 Watt @ 4 Ohm < 1% THD+N CEA-2006-A Specs – Sn Ratio: > 80 dBA (DDSP) (ref: 1 Watt into 4 Ohm) Pro 1|10 – Sn Ratio: (AP filter 10Hz / 22kHz – DDSP – 600Wrms ref) 108 dB Click here to...
Mosconi 8TO12 Aerospace Digital Sound Processor for Audiophile Grade Stereo Systems
FEATURES: 8 channel input 12 channel output Digital input and output (Toslink) Coax input (RCA) Highest resolution, e.g. time delay in 0,02 msec/step All settings in real-time USB and optional BT adapter (MOS-BTM), for adjusting by PC, Android and BlackBerry (*) smart phone apps Low-Level or...
--Subwoofers
Focal E 25 KX High-Performance K2 Power Series 10-inch Subwoofer
Focal E25KX Series 10” Subwoofer25cm (10″) SubwooferCompact sizeHigh powerFor sealed and vented enclosure [0.6 to 0.77 cu ft (17 to 22L)] in sealed for optimized performanceSpecifications:Woofer diameter: 10″Voice coil diameter: 2-9/16″ (65mm)Voice coil height: 2 3/16″(55mm)Tweeter Composite: K2...
Sounds Good Stereo
Sounds Good Stereo - High-End Custom Car Stereo Solutions
