2014 Screw suspension bounce
SCSVT
Carolinas
+1 on tire pressure for sure. I did a bunch of tests varying the pressure by 2 lbs each time and finally settled on 38 psi as the sweet spot that I like. Absorbs a lot of the bounce
Canuck714
San Antonio TX
Did you get this figured out?
As a few have mentioned, tire pressure and tire choice can make a difference. I run 35-37 psi on a 37 inch tire for comfort (D load).
If tire pressure doesn't get you there, then something is up with the shocks.
