2012 Raptor 6R80 larger fluid pan
tmp123
Does anyone know where I can buy a bigger Trans oil pan.
Had my 6R80 rebuilt with good internals recently ( see video) and some people recommended a larger pan.
Thanks
COBRA90GT
HOCKEYTOWN ® MI
There's a few companies out there ( Mag-Hytec, PPE, Performance Automatic, AFE & maybe a couple of others, considered it myself awhile back but never bought one ).
I remember seeing an older thread or two on here for the Mag-Hytec sold by Freedom Motorsports (or maybe it was for the diff cover?), could try running a search on the board for it to see what else is floating around out there...g'luck !
bsimms89
I just installed the AFE pan, was very happy with it, hold 7 quarts more than oem (was the biggest increase of any after market pan I saw), it fit in no problem even with my kooks exhaust and green cats, I did it the same time I installed a B&M transmission dipstick and saudi trans cooler.
Bozz
Royal Smart A$$
Nashville, TN
I want to put a new pan on my 2012 and am debating between the AFE and the PPE. The PPE only holds 4 more quarts, but looks a bit more shallow than the AFE. I don't want anything that is going to hang down much further when off-roading.
How far down would you say the AFE extends vs the oem pan? I can't tell from the photos, but I would guess 4-6 inches? Unless the photos just exaggerate the depth optically.
bsimms89
It’s lower than the oem pan, I’m not sure how much, but it’s not as low as the frame cross member just in front of it, it’s not the lowest thing on the truck
2012SCSVT
CA
I was wondering if you think it would sit above a skid plate if a plate went from the trans mount to the aft front suspension cosmember under the engine
Latchkey Kid
Blue Ridge Georga
I have an extra one never installed. Long story very short I ended up with 2.
Latchkey Kid
Blue Ridge Georga
I had a custom spider guard built for mine. Hangs lower than I prefer but looks and performs great. They can build it for any pan. They did my diff as well
