Elevate Leaf vs icon vs deavers
06z
So Cal
How come that advertising doesn't mention how much suspension travel you will gain?
Are you referring to a stock truck? If not, wouldn't that depend on the setup in your truck? Weather you have a bed cage or not? 16" or 18" bypass shocks? Is the bed cage setup at with a 1 to 1 ratio or not? This would be the shop installing it MUST CYCLE the suspension for true travel numbers.
TomDirt
Hesperia CA
The suspension droop isn't controlled by the shock length. At least it shouldn't be. If you just swap out your spring pack for Deavers, Icons, etc, you're not required to replace & relocate your shocks to use them, the same as if you swap out your factory coilovers for any "bolt on" units.
06z
So Cal
My truck has Deavers sprung under and has 9 leaf springs. Very plush ride the way HM built the cage and cycled it 1 to 1.
