Worth pulling the engine for multiple upgrades?
jdm_sixtwo
11MPG is average, right?
Beaufort, SC
Yeah like Gumby said, if you’re not afraid to blow it up, LKQ has tons of super duty’s with 6.2s, and they only charge $500 per engine if you pull it yourself. I always was told to never boost an engine over 50k miles because you’d send a rod out sooner or later.
J
Justbob
MD
So I’m a little confused, the thousands of SC Roush and Whipple charged Gen 1s all have strengthened internals…..or they all have blown up and are rebuilds….or are all time bombs and the dozens I’ve seen listed here with 122k-170k miles all are a rarity ? Like I said, the 700hp seems obviously at the outer limits, but the 590 kit, with headers seemed realistic (I don’t plan to beat on it).
Gumby
Nashville
I personally Don't think you will have a problem, I would do the oil pump for sure. Pop off a rod cap or 2 Might as well take a look. I have seen guys put huge NOS kits on Junk and Run the crap out of them. if you tuned well and have good oil. I say it will stay together. JMO. Up to 700
Really comes down to the tune go a little lean.....Window!! loose oil....Window.....twist it up to far... Suck a valve....Window. But you are not building a Drag car. I think you will be fine and will be fun to drive. You will pass everything BUT the Gas station.
Canuck714
San Antonio TX
If you are pulling the 6.2 to add long tubes and a blower, 100% do the oil pump, spark plugs, maybe do water pump and alternator while you have everything apart etc.
A good JDM tune at 600hp and drive it... Make sure you run good fuel and keep the oil clean (5/30)
After beating on mine for 125K miles the only thing I ever thought about was breaking a valve spring as that has happened a couple times on 6.2's
J
Justbob
MD
Does anyone know what the “shop manual” calls for time to pull the engine? Trying to figure out if it’s more or less work (and less pain) than doing each separately.
WHBD
MD
Would you mind shooting me or linking where you can find this pull a 6.2 yourself for $500? I'm at 228k on mine and while it has been essentially flawless, I always have dropped valves on my mind.
jdm_sixtwo
Beaufort, SC
Check the stock of your local LKQ and see if they have a super duty with the 6.2. Their pricing says it’ll only run ya $595 if you pull it yourself and it’s got a 90 day warranty too. I’ve seen a few 6.2 trucks go through my local LKQs.
TomDirt
Hesperia CA
I've noticed all the youtube videos doing a gen 1 SC install conveniently skip the part where they get to the back of the motor, then suddenly they are done and it's running down the highway. Thats never a good sign.
