hkguns
- Joined
- Jul 30, 2016
- Posts
- 1,173
- Reaction score
- 893
I had a couple of questions in Private messaging so I thought I would post this here.
Wiring the upfitter switches is super easy.
There are two sets of wires under the engine compartment on the passenger side, just to the rear of the battery, near all of the connections passing through into the cabin. Mine were taped off to the other wire bundles.
The hot side is nearest the battery, the switch side is nearest the firewall.
Example: To connect the Baja Designs lights all you do is run the Red (hot) wires to the battery side wires and the Red/Black to the switch side wires.
You can use a wire nut to connect several together to a single upfitter switch connection.
The wires are color coded as follows:
2017 Wire Colors
AUX1 - Green(solid)/Blue(stripe) - 15A
AUX2 - Gray/Yellow - 15A
AUX3 - Violet/Orange - 10A
AUX4 - Brown/Blue - 10A
AUX5 - Gray/Orange - 5A
AUX6 - Yellow/Violet - 5A
2018 Wire Colors
Aux 1 - Green/White - 15A
Aux 2 - Brown/Blue - 15A
Aux 3 - Gray/Yellow - 10A
Aux 4 - Green/Yellow - 10A
Aux 5 - Brown/White - 5A
Aux 6 - Green/Orange - 5A
Remember, the engine needs to be running in order for your upfitter switches to work. Hopefully this saves someone some time.
2017 Wire Colors
2018 Wire Colors
