Which Geiser springs!?
Raptor812
evnaville, indiana
First off. I’m very new to the Raptor community. I came from a Ram Powerwagon. Anyways, looking to replace my soft front springs with possibly a set of Geisers. I know they have 2.5” and 3” springs. My question is this. I have seen posts about the Eibach 3” springs only giving a 1.7” lift on the live valve fox shocks. Are the Geisers the same way?
OffroadAlliance.com
Boston, MA
They should give you a true lift of 2.5" or 3". They might settle a small amount but you'll still get the desired lift amount.
Coastal
I’m looking at this too, and based on a lot of reading, with a 1” lift in the back (deaver), the 2.5” should bring you to dead level. The typical nose down rake should get you 1.5” of difference between front and back.
In my research, I read I should be able to get these delivered for $500, but haven’t been able to find that deal- anyone else have luck?
Granelli
Nevada
Do the Geisers have the same issue as the Eibachs where they rebound hard and click? Seems unavoidable when you lift the truck and lose down travel.
