Wet Passenger Floor, All possible issues explored.
downforce137
In Diana
rain water splashed from the tires can def get into the evaporator drain before the TSB is done.. i believe thats how mine was soaked but no issues after the bulletin was completed
GLF5
New York
On my 2019 there was a leak at the passenger side cab vent (between the cab and the bed) which wet the entire passenger side floor, front and back.
Bee
Connecticut
I had to do the Ford TSB twice.
I found this information on another post in this forum. You simply can NOT just pop on the rubber elbow and call it done (https://static.nhtsa.gov/odi/tsbs/2019/MC-10168762-0001.pdf). It will still leak.
This is a channel or groove on the underside of the plastic spout. It is not represented well in the crappy pictures in the TSB. The second time, I used a sharp wood chisel to shave it flush so the rubber elbow gets a good seal. I also used silicone.
