VHF Radio Mounting Tips
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
I was going to wire to the passthrough wires but in the radio forum posts there was a link to a mobile site that says the radio power HAS to be connected to pos/neg on the battery directly. I have a Kenwood TK7160H-K 50watt. Would I be able to wire this up like you with the passthrough or is your unit differnt?
it does not have to be wired directly to the battery. they say that because of the current draw. yet some radios give you a cig plug adapter and the oem plug is rated at 15 amps. ideally you wire to the battery for ease of access incase a fuse blows. but there are large enough wires at the bcm to connect power there if you really wanted. however make sure you got the right wire. the additional draw on certain circuits can overload the electrical system on that line.
nfsraptor
SoCal
Thank you!! I am currently wiring my radio up have the passenger seat out and wiring it all up. I'll post some pics when I am finished tomorrow.
nfsraptor
SoCal
Here is my installation! I unbolted the center console and seat and got the wiring to the pass through wires. My favorite part is that I mounted the nmo antenna on the light bar rack so when I have to park in a structure I don't have to remove the antenna.
OriginalToken
I did all three of my VHF/UHF antennas on a power lay-down light bar. My HF antenna is not fixed, and cannot be layed down, but the whip is on a quick disconnect, it takes about 5 seconds to take the whip off.
By the way, I ran my coax's all in via the pressure release vent behind the rear seat.
Antennas up:
Antennas down:
T!
nfsraptor
SoCal
Antennas up:
Antennas down:
T!
That is amazing so badass! I am sure my coax will get torn offloading I ran it down the bed along the top of the framerail and up the passenger floorpan but when it does I'll rerun it where you did.
OriginalToken
It was pretty easy, although thin hands help. Straight through either the grommet at the front of the bed or the access hole at the front bed stake pocket, and then into the back of the cab via the pressure release vent behind the rear seat. Can be a pain to get to those spots, but nice, clean, and no holes to drill other than a slit/hole in the replaceable bed grommet.
Also then none of the coax is anyplace under the vehicle or above the vehicle to get snagged on limbs etc.
Downside to using the lower bed grommet is if you put things in the bed that can slide around they could pinch/crimp the coax. Then it should all go in the stake bed access hole, if possible.
T!
nfsraptor
SoCal
T!
OH that's why I didn't see it I still have the factory plastic liner so those are probably under the liner.
waveslayer
CA
What vhf is that? I have the same gun safe and S&W performance center M&P shield. I plan on doing a group run in September and want to have the proper gear.
Chase package from PCI radios my man. It works perfect. I then bought a magnetic antenna mount that bolts inside the bed of the truck, since it won't stick to our trucks. A guy sells a little metal bracket. I zip tie the antenna because I punch it so often it rattles off! Ha ha
My wife thinks I only have 3 guns
Wfo
Syracuse
Can the factory fm antenna be dedicated for the vhf radio? I never use the fm radio.
